Leimbach 0H104 with 0H995(12V) in Wedico 966G?
  • Hi
    Does anyone know if this will fit my Wedico 966G ??
    I can't find any drawings to compare mounting holes
    I believe the combination of Leimbach 0H104 with 0H995(12V) will give the CAT the power it needs :thumbsup::thumbsup::thumbsup::thumbsup:
    Best Regards
    Carsten
  • 0H104 is setup for approximately 11bar, same as your original pump, unless you increase the pressure since the pump is capable of upto 16bar with a brushless motor 0H995. My guess is the mounting holes are identical to your original pump.
  • Yes but 0H0104 give much more ml than original and that's why its a slow CAT (380ml standard)
    So the 0H0104 with brushless give 600ml and think its going to be big improvement
    I saw at getriebedoktor the 200 ml and 450ml (0H0104) have same holes so the 380ml think have same
