Some more photos that I left behind
Excavator rc hidraulik JCB JS330L
the hydraulic
Vom Feinsten ,Klasse gemacht
Hello, I wanted to ask if you can put some pictures and design of hydraulic valves?
thanks -
wow, great job! looks really professional!
Hi,EX1200, hydraulic valves are purchased second hand, if you want the designs, I can give you.
bye
Hello, I could advise some of you a sound module for the bulldozer? make, model, vendor etc, and for a dumper,
thank you very much
Maybe you could give me the illustration! I'd thank you for life!!
Ok, EX1200 this weekend I put the photos.
regards
Ok thank you
Hallo zusammen
Hi all
The hydraulics in solidworksThe hydraulic and finished
The support of hydraulic pipe
Hello!
Exellent work, looks great the Cylinders.
Regards Martin
You are ready and tested with 25 kg of pressure
Sorry, not what happened to the photos
Klasse was du da baust
Sorry to bother you again, if the photos do the valves removed and you may make them in detail?
thanks -
Danke for the Kommentare.
Es Ist Der die Umdrehung Hydraulikpumpe System.
Of this System ist ermöglicht IHNEN, legte she Auf Die Pumpe entfernen Auf und ohne Demontage des Oder der Scheiben Elektromotors.Thanks for the comments.
It is the turn of the hydraulic pump system.
This system allows you to put on and remove the pump without removing the pulleys or the electric motor.Das System verfügt über einen eigenen Lüfter
Since the pump is mounted
You will tell me if you like the system
