Dienstag: 06 Oktober 2026
    CAT 330D-L
    • Erik79
    • 28. April 2014 um 00:13
    • stvo
      Schotterkutscher
      • 23. Mai 2017 um 19:46
      • #41
      Great video!
      I also like the pressure drop when the zylinder is not used!
      So you have a overall pressure of 5bar when the system doesn't move?
      Glück Auf!
      Stefan
      MBS - Modellbaustelle Süddeutschland e.V
      Modellbaustelle Süddeutschland - unsere Homepage
      *Weil dabeisein nicht alles ist*
    • Erik79
      • 30. Mai 2017 um 00:56
      • #42
      Thanks STVO! :D
      Yes, when the model doesn't move the pressure drop to a minimum level roughly from 1 to 6 Bar depending from the flow supplied by the pump at the minimum RPM. The less the flow, the less the residual pressure when the center is open.
      And if someone need it for some reason, the valve can be changed in close center simply avoiding to drill a hole in the aluminium head of the distributor.
      Now i am ready for selling.
      See you.... :)
